Dear All
The linkage bar keeps dropping off and I will eventually get round to doing a repair using one of the kits available. Its off the car now.
Looking at it today... I noticed 3 of my swirl flap actuators * will actually rotate 360 degrees - (obviously not the one connected to the motor).
I expected them to hit a "stop" when closed... like a throttle butterfly.
Is that normal ? - are they broke inside ?.
Matt - brighton
* the plastic disc with the peg that sits in the inlet manifold
Dear All
Matt - brighton
You must have a very early 1.9 159 to have the bar type swirl flaps ???
Aluminium manifold with plastic flaps??
Ned
Discussion Starter #3 (Edited)
Yes
2006
Not looked inside the manifold but the rotating disc with peg is plastic and its an alloy manifold.
My post wasn't clear - I haven't taken anything apart or off the car (apart from the bar that connects the x4 discs) - its just the plastic part you can see next to the glow plugs
I didn't realise there were variations.
Ought they twirl without stopping or should they hit a stop when in closed position ?
Thanks v much for the quick reply
ps - its just the bar thats off the car - not the manifold
Matt - brighton
Yes
2006
Matt - brighton
Yes the very early 1.9 159's have the metal manifold with the plastic flaps, it was only the first 3-4 months of production then they went over to the plastic manifold with metal flaps which come off and destroy engines and turbos
We remove the manifold, remove the swirl flaps and weld up the holes and refit with EGR delete. It is possible to do this job with out taking the cam belt off but much easier to do it with belt off
Ned
