Hi there
Car : GT 3,2 2005
first question :
Have had a few different spring/dampers combination so far, but none is really any god.
Original: did not last long and was very soft but at the same time crash when hitting sharp edges. quite expensive to replace with OEM parts.
Koni Fsd/Eibach: a fault in the construction of the front dampers meant that the front of the
car was 2 cm higher than the rear - not a pretty sight... so no good
... Koni has accepted this problem on the GT (not a problem on the GTA)
AP Fahrwerke adjustable coil overs: The screw to adjust the rebound broke the first time of adjustment on the rear dampers. not good quality .. the ride is firm and compliant on good tarmac, but as soon as the car hist uneven tarmac it bounces and is all over the place. when hitting sharp tarmac edges or holes it feels like the car is falling apart (actually my new bushes has been destroyed by this suspension in 1 year). I must admit that i do a lot of town driving on Copenhagens bad roads.
So what is the best suspension if you wan't a sporty but still comfortable ride ... ?
next problem:
when starting the car in the morning a weird rattle from the engine bay is present. At the same time the revs go up to 2000 rpm when cold (not a problem when the car is warmed up). The problem is present as well when i start to drive even when the car is warmed up: if i start in first go second gear and then release the clutch the revs go up ..
Have had the car to many different workshops, but nobody knows what's wrong ? really hope you out there can help me with this..
regards, jeppe carlsen, Denmark
Car : GT 3,2 2005
first question :
next problem:
