Hello, know its been covered a million times but originally this was a PM written out to Seadart, who has kindly send me a pair of trailing arm (spring pan) inboard side bushes. Legend! :thumbs:
I thought I'd open up the discussion to others who might add value to the discussion.
The story so far is simple: my car just ticked over 90000 miles and theres little history of the rear suspension being seen to. Both trailing arms (spring pans) were replaced in 2002 (at a parts cost of £162). That is all.
A key issue here is: I enjoy the handling of my car! I've described it before as "funky" (low speed oversteer, but nothing out of the ordinary). Most importantly, the ride over bumps is comfortable.
Now, this years MOT advisory said:
- Both nearside and offside rear suspension arm rubber bush deteriorated but not resulting in excessive movement
- Offside rear upper suspension arm has slight play in a ball joint (I assume this is not a polyflexible part?)
So, to kick start the thread: which bushes should I change to prevent subframe death? I am guessing numbers 5 and 6 are critical to subframe health?
I'm reluctant to replace them all since:
a) I'm skint
b) car handles fine, don't want to do anything extreme
I'm interested in the "improved" suspension joints that the V6 uses... can these be fitted to a TS?
Sorry this is a bit of a ramble... thanks guys!! :thumbs:
p.s. a £17 front wishbone was fitted 3 years ago and just wore out this year so I recommend not spending that little... but this has been said before!
a) I'm skint
