Supersprint 156 center pipe 753113 - WARNING
Hi All,
Anyone of you installed or got installed the Supersprint center pipe 753113 60mm diameter on a 156 ?
I am using the back box SS 753125 and my workshop called me to say i need an adaptor in between both like with the original center pipe ?!!!
It seemed amazing to me ... ? :eek: :eek: :eek:
Thanks for sharing .
Giles
The last 10cm (approx) of the Supersprint centrepipe reduces down to the same size as the std pipe (so it can be used with the std rear box).
So if you need an adapter for the std pipe, you will for the Supersprint too.
Thanks a lot David ... this is a very precious info. I actually have the adaptor since i was running till now the standard center pipe + the rear Supersprint ...
Though i am amazed of such a choice technically speaking !
Giles
Dear All,
I received confirmation from Supersprint that in fact as advised by David above ... the last 75mm of the 156 center pipe have a diameter of 55mm ... and NOT 60mm as advertised clearly below :
http://www.supersprint.it/a_prodotti.asp?modello=ar1565
This is to me an abuse of the customers that we are ... and it is strongly disappointing from Supersprint that i believed to be a reputable company :mad:
Giles
