Hello All , anyone find their 159 subframe ( rear or front ) suffering rust .. ?
Anyone know good place to get repaired ?
Administrator
It's not just UK import cars that it's an issue on unfortunately, it's also an issue on some of the Irish cars.
Some owners are sourcing spare subframes & treating/repairing them in advance then swapping them over themselves or getting a garage to do it. This thread in the 159 Tech Lounge is worth a look if you are interested http://www.alfaowner.com/Forum/alfa-159-brera-and-946-spider/544066-159-rusty-sub-frame.html There's a good few others if you do a search.
Didn't any of this come under the anti-corrosion warranty or was this just body work related ??
I phoned FIat \ Alfa R today > to enquire re warranty ... seems you need to take it to dealership first so they can inspect it .. ( at a cost) then they decide if warranty or not "depending on how bad it is"
Administrator
Sounds like it's worth a try, good luck, there have been some successful claims.
Ouch! rusty frames.... Yes I've repaired the frames on both our 159s. It's pointless buying a new one for €1000 as the paint from the facotry is rubbish...
I took mine and had them sand basted and 'touched up' a few bad welds... Cleaned, coated with 3 coats of Galvafroid:
Zinc Rich Galvanising Coating - Galvafroid - ParkerTools
Then spray painted silver for the 'bling bling'.. :)
Here is what I had before:
http://italiancarclubireland.com/wp-content/gallery/159-subframe-rust/20140318_140311.jpg
http://italiancarclubireland.com/wp-content/gallery/159-subframe-rust/20140318_140341.jpg
After sand blasting:
http://italiancarclubireland.com/wp-content/gallery/159-subframe-rust/img_20140326_120719.jpg
Galvafroid drying in garage:
http://italiancarclubireland.com/wp-content/gallery/159-subframe-rust/frame_prepped_01.jpg
And finally the treated frame going back on car:
http://italiancarclubireland.com/wp-content/gallery/159-subframe-rust/img_20140430_113418.jpg
Costs....
Well the sandblasting is around the €150 mark.
Galvafroid was €60 for tin which with do 1.5 frames.. yes one and a half!
New Radiator support brackets were I think €80-ish (they will be rotten as well)
then you have mechanic labour on top.. steering frame and suspension needs to come out.. I would consider this job as part of a complete front suspension upgrade/replacement.
I've one spare treated frame if you're stuck? can post up detailed photos if you wish?
