Howdy folks,
Super site you have here. I was hoping my first post was going to be a jolly affair, alas this is not the case. I've scoured the forum for wisdom but I am still at a loss. Perhaps you chaps can shed some light on the issue:
2004 GT 1.9 JTD
When stationary, and with the engine running, a wickedly strong smell of exhaust surrounds the car, way too strong for the JTD. It surrounds the car to the extent that it gets into the cabin and chokes the occupants. Only way to stop from asphyxiating is to have the fan off or on recirculation. Open the door to admit/drop off a passenger and the noxious stench gets sucked into the cabin. The strength of the smell has also increased over time. I bought the car recently, unaware of the problem. Started to notice it as the strength of the smell increased.
Here's what's what:
No drop in performance throughout the range.
Getting 32mpg.
A little black smoke on startup and initial bursts of strong acceleration.
No drop in oil level since its service a few months back.
Recently renewed air filter, oil filter, diesel filter, and oil.
No fault codes reported.
Recently replaced lower turbo hose.
Upper turbo hose looks OK.
Cleaned EGR valve and solenoid.
Cleaned the MAP out.
Disconnected the MAF and there was no difference in smell/performance.
Had the exhaust checked over and no faults found.
Brought it to two garages. One reckons the piston rings are gone, the other cannot find anything without my putting down "big money" to investigate.
Any advice would be much appreciated.
2004 GT 1.9 JTD
Here's what's what:
Getting 32mpg.
