Hi Guys
Just changed the headlight bulbs on my V6, jees they dont give you much room on the near side!!!
However, whilst struggling near the battery I noticed a bit of pipe sticking up. It is about 100mm long, 10mm in diameter, comes out of a larger 16mm(ish), pipe with a capped and threaded end to it. Any ideas what it is and should it be connected to anything, looks like it should???
wrinx
Hi wrinx ,
without looking at my own car and at a quick guess I would say that,s your headlamp washers feed pipe----no? Alfapat :rolleyes:
Hi wrinx
It's the filling socket for cooling liquid. I have the same on my V6. No danger in unscrewing the plastic cap, there is a valve underneath.
But then again: don't tamper with something that works!
Christian U
Discussion Starter · #6 ·
eek! just a quick note about air con it is against the law to vent the gas into the atmosphere,it can also kill you. eek!
