1 - 18 of 18 Posts
Given the recent good weather, I ave mostly been driving my Spider. Had to pick up a BBQ/fire pit today and took the GTV and noticed a bit of a strange noise... I can only describe it as a whirring/droning sound which is related to road speed and not engine speed. It sounded to me like it is coming from the front but the Mrs was adamant it was coming from the rear. I quick check when I got home confirmed that the tyres were properly inflated and the wheel nuts were secure. No undue movement in the wheels. I’m guessing the next step is to jack up each corner in turn and spin the wheel listening for anything untoward.
I’m guessing it could be...
a. A wheel bearing; remove hub, press out old bearing and fit new one?
b. CV joint especially since I had the obligatory split boot last MOT. Can this be replaced in situ or does the drive shaft need to come out? Hub off?
c. I’ve got grooved discs but they’ve been on a while and never made any noise.
Any other suggestions or ideas? Thanks in advance.
You've listed the most probable options. I'd say with the discs it could be a sticking/binding caliper that's just dragging on the disc now where it didn't before, causing your drone. One of my rears stuck last week and was squealing something awful, tapped it with the wooden handle of a hammer and it just freed it.
Thanks... I’ll have a proper look tomorrow. Fingers crossed it can be fixed with a quick tap from a hammer.
When the wheel bearing went on my spider i couldn't work out which one it was by jacking up and spinning the wheels,they seemed fine and noise free.In the end i used a 12v cctv mic patched into the aux of a portable radio in a very Heath-Robinson manner and placed mic near each wheel in turn and drove around a bit til i found the culprit.It was offside rear,even though i was sure it was coming from the front before testing
Many thanks... I’ll get it jacked up today and see what that reveals, failing that I’ll try some more in depth investigation. Is there any easy way of telling if a CV joint is on its way out?
How I find out where the duff wheel bearing is ,I go rounda bend ,preferably long & when (if) the noise disappears thats the side. As you go around the corner all the weight is transfered & the slack is taken up so no noise momentarily...HTH?
Discussion Starter · #8 ·
Thanks again for all the advice... had a play at work going forwards and backwards on full left and right hand down. No knocking. Tried some ‘spirited corning’ on the way home from work, albeit hampered by getting stuck behind a tractor. No change in the sound. Jacked the car up and the first wheel I tried produced a sound when rotated by hand that was somewhere between a bag of spanners in a tumble drier and C-3PO banging one out in a tin bath. Just to be sure, I checked the other wheels and all good.
Any advice on changing a wheel bearing? Although I did check my MoT history and beginning of last year I had the other one done on the back at a local garage who did it for not much IIRC so I may give them a call.
Rears are relatively simple, they are just bolt on, the fronts are pressed in so a bit trickier unless you have a press handy.
Discussion Starter · #10 ·
Cheers Steve... didn’t realise it was that straightforward. Just watched a real time video on YouTube where the geezer changed one in 5 mins.
Discussion Starter · #12 ·
Not that scary is it, I take it your noisy one is a rear?
Yeah... back right. Any recommendations for what bearings to use. I think I got a SKF fitted last one I needed. Annoying thing is about a year ago someone was selling 2 brand new Alfa ones on eBay for about £50 and I thought about buying them ‘just in case’ but never did.
Skf are a good buy, that's what I would use. I always miss the 'just in case' bargains too!
Discussion Starter · #14 ·
SKF bearing ordered... took the wheel off today and there’s nothing rubbing and the noise is definitely coming from the bearing. Funny how you never need the parts you buy ‘just in case’ but always need the bits you don’t buy.
Thanks all for the help.
Strangely I’ve just been watching this it might be of some use ?
Discussion Starter · #16 ·
156 V6 3.0 Sportwagon
I've had a very similar problem with what sounds exactly like worn wheel bearings. For me (after a lot of expense replacing wheel bearings), the noise persisted. It eventually turned out to be road noise from the tyres themselves. Once I changed the tyres the noise vanished.
Discussion Starter · #18 ·
New wheel bearing fitted and noise gone... happy days. Thanks all for the advice, much appreciated. Took less than an hour from start to finish including a test drive.
1 - 18 of 18 Posts
