1 - 14 of 14 Posts
This applies to all 147s, 156s and GTs equally. Now the cars are older, it is quite common to experience multiple electrical faults which are due to the deterioration of electrical connections.
Any car with strange faults should firstly have this attended to before looking any further. This is especially true if the car won't start or if it only happens sometime after setting off. The reason is electrical load through a high resistance connection increases temperature which increases electrical resistance and so the downward spiral or plunge begins. The fix is very simple though. However, I simply used a single jump lead between the battery and engine to properly earth it to temporarily alleviate the worst of the symptoms. There was also voltage loss in the positive circuit.
Pay close attention to what is suggested. Look out for oxidation, corrosion or blackening on any parts. Don't forget to check positive wiring to and through maxi fuses.
As per title, the 99 156 TS developed some strange faults. Firstly, the starter motor would not operate. That almost immediately progressed into fluctuating reading on the coolant temperature gauge, non-operation of engine cooling fan and then lack of power, failure to respond to wide throttle openings and failure to rev above 4000rpm. This all happened almost immediately. Finally, the speedo was lost and the ABS light came on.
The fix was simple. I cleaned up battery terminals and posts, cleaned up earth point and terminals on the left front wing near fuse box in front of battery and gearbox earth stud. Similarly, earth points at engine ECU and above thermostat were cleaned thoroughly.
The positive cables to the maxi fuse boxes were given the same treatment. Finally, these parts were sprayed with ACF-50 anti-corrosion spray.
All fixed but surprised I was caught out as I've given advice about just this. What I didn't realise was just how bad the earth connection at the inner wing was.
The conclusion is don't forget about the electrics. These cars are now older so need this maintenance to avoid breakdowns and paying mechanics to scratch their heads and make the sucky sound.
Discussion Starter · #2 ·
Just a quick update on this; yes, car is now fixed and as an added bonus, the headlights seem a bit brighter and the wipers seem to sweep with more vigour.
On newer CF3 engines, it is likely any strange recurrent 'low voltage' errors in things like the ABS or airbag should be eradicated.
Discussion Starter · #7 · (Edited)
Low charge warning fault
That only has value if there is voltage drop under high current loading. If things were that way I'd have got new wiring but voltage loss is now negligible.
That said, look here as what was the real cause is oxidation of positive terminals between alternator and starter motor;
Low battery charge warning fix
Interesting! Might do this. As we see above and have heard/read over the years, our beloved alfas are very suspicious of any variation in the voltage they receive....and spit the dummy out easily due to this.
Seems an easy upgrade for potentially very good benefits
Cheers for this
Tony
You'r welcome.
Does anyone have pics of engine ground wire on alfa GT jtd? Where is located that wire?
Discussion Starter · #9 · (Edited)
Diagram of main earth's from battery.. There is also an earth at the A pillars for interior equipment but possibly things like wipers. If the car hasn't been damp due to leaks or driver not putting airflow and heat to floor in cold wet weather, there shouldn't be an issue with the cabin earth points.
What did you use to clean the terminals? I've used baking soda paste and a toothbrush in the past and that worked pretty well.
Discussion Starter · #12 · (Edited)
Simply a wire brush but I think it was a rotary one on a drill. I guess some of the rust eating acid could be used at major terminals/earth points if necessary. I prefer new terminals for anything smaller.
Discussion Starter · #14 ·
Other manifestations of earth faults and solution here;
1 - 14 of 14 Posts
