Prior to having BCM replaced if I switched stop start off on dash switch it would default to on after every ignition off and back in. Now I have it back if stop start is switched off when I park up etc and turn car back on stop start remains off, is this normal?
Only reason I ask is with the knackered BCM I don’t know if car was behaving normal or not prior to replacement.
Post 2014 , the Giulietta DNA setting remained as before switching off when you started it up again as did the S/S.
Suppose new BCM will be latest post 2014 type then as that would explain it,didn’t notice if DNA remained the same will have to check
I think if you select A it stays on at the next restart but D goes back to N. I have a 2010 car, the wife's Fiat 500 stays with S/S deselected for months on end.
