1 - 20 of 46 Posts
Since a few weeks I am the proud owner of a Giulietta QV. It has H&R springs and standard shocks, running on 17". It drives good but I am convinced the turn-in could be improved stil, sharpened up.
On my other car (156 GTA) I had
Eibach ARB's installed last year and that greatly improved the turn-in of the car, much more than the B8 shocks that were installed earlier.
So I was looking for stiffer ARB set for the giulietta as well but can't find it. Eibach does not offer these, other manufacturers neither.
Anyone ideas?
Switch to tyres with better turn in until there are arbs available.
My Hankooks turn in lightning quick compared to the Pirellis and Michelin. But as a downside they also are more prone to tramlining and filter less vibrations.
Try moving to 18s, less sidewall means better turn in?
  • Like
Reactions: Freds GTV 2001
My mistake - I am already driving on 18"
But the problem is not the tyres.
Once you've experienced the effect of upgraded ARB's (like I did on my 156) you'll understand why I am searching for those.
Really makes an enormous difference!
I did have a GTA rear arb on my 156 so yes, I know.
I'm only poiinting to a temporary solution as there are no aftermarket sway bars available and all Giuliettas use the same size.
is a sway bar the same thing as a strut bar?
The rigid bar between the tops of the shock absorbers?
So sway bar is at the bottom, and the strut bar is at the top of the shocks?
Would one use both?
Why can I only find strut bars for the Giulietta?
Would one use both?
Yes correct.
It depends on the type of suspension, but most cars have sway bars, so whenever you'll add a strut mount you will indeed have both.
Struts bar are easier to install, often bought for the looks rather than perfomance gains and less "hardcore" than a stiffer swaybar. I guess that's why these typically hit the market sooner than a sway bar.
No, you couldn't have passed it up.... That is almost cheaper than domestic shipping from some companies.
Discussion Starter #19
why not order read and front - then under/oversteer ration remains unchanged, but you'll get a more direct steer-in into corners.
And keep us informed on whether they fit!
Progress Technology only makes a rear ARB for the Dodge Dart. I'm pretty happy with the front end setup I've got and I don't want to invest too much money encase it doesn't fit. Eibach makes a front and rear aftermarket ARB for the Dodge Dart but the total cost with shipping would have been well over $600 U.S. I paid $188 U.S. (shipped) for the Progress Technology ARB. I'm just hoping they will honor the quoted shipping cost and actually send it.
1 - 20 of 46 Posts
