1 - 20 of 31 Posts
I've been trying to sort the stereo code on my (new to me) 147, got the 'wait' message, so left key in ignition for an hour, still there so left it a bit longer.
Just went out to find all dash lights / stereo off & when key is turned beyond MAR, all I get is a relay type sound, engine not turning over :confused:
Any clues?
L
do you have a multi-meter? measure the voltage of the battery. Do you know where it is located? ;) Voltage should be > 12.4volts to start the car. You didn't leave the key on with the lights on too, did ya? :cheese:
L
the radio code should be stored into the 'body computer' & registers via the CAN system. The radio maybe from another car & therefore is not coded to your car. PM to me the serial number of the radio i can generate the required code. You may have to cut a small wire at the rear of the stereo to enter this code. Alternativelythere maybe a broken wire at the back of the stereo that would explain why the code is lost.
Cheers Lacken, flat battery indeed :thumbs: , nothing left on lights etc
All the CANBUS is new to me :eek: - thought I'd bust something :lol:
I'll give the code another go (generated using BP_PgAlfaFiat.exe, but have also asked in the 'radio code' thread)
If I need to tinker with the wiring, I'll gave ya a shout :cool:
Cheers :D
L
BP_PgAlfaFiat.exe should generate the code required. Is it a 147 stereo ( 2 top corners are rounded ) or a 156 stereo fitted?
147 type.
Fail number two of the day, I fed the code in wrong, so will have to wait to try again - better sticking to my 156 methinks :lol:
L
You should call yourself '2 of 2' :cheese:
what you doing with the V6?
is the 147 now your daily commuter?
V6 off the road for a bit, new ARB's, bit of welding etc, so got in touch with my female side & bought the 147 for daily running :thumbs:
You don't need to leave the key in the car with the stereo AFAIK 0ofer:p. If you just come out the next day I think the stereo will have done it's wait thing and be ready for you to c0ck it up with you fat fingers again put the code in :)
L
go for a 40 min spin one direction & then on the way home it'll be asking for the code. alternatively remove the stereo & hard wire it to a perm feed from a battery
Cheers, you got me sussed eh? :p :lol:
Discussion Starter #15
Where does that leave me? Afterermarket option only?
L
snip time, there is a very thin grey/yellow?????? wire, if you cut that you can enter the code for the radio,
NOTE: take a look & tell me the colours of any small , i'm not too certain about the Grey/yellow
It must a replacement unit, the 147 shouldnt need a code for its original
That's what I thought? I thought that the radio is actually coded to the ECU so you can only swap them with the use of Examiner ... but I could be wrong
Discussion Starter #18
Will have a look in the morning, cheers :thumbs:
Discussion Starter #20
Might find out tomorrow if I have to dive in with the wire snips :eek: :lol:
1 - 20 of 31 Posts
