1 - 20 of 46 Posts
I've ordered a Stelvio for delivery early next year. I find the size of the UK plate too big aesthetically as it intrudes too much towards the grille and was wondering about getting a shorter registration that would fit on Italian sized plates and plinth. I was reading a Giulia thread about the same idea http://www.alfaowner.com/Forum/alfa-giulia/1052186-smaller-front-number-plate.html and wanted to know if anyone had any idea about sourcing the Italian plinth part. My dealer says they need to fit the UK plinth as part of the PDI but I could always replace it myself with the Italian plinth as long as the screw hole positions matched. I'm still investigating if they actually NEED to fit the UK plinth as part of some official procedure - owners on the Giulia thread seem to be instructing their dealers not to fit it. Anyway if I can find the part and successfully compare, then I'm happy to fit swap myself. The pic attached is what I sent the dealer by way of explanation.
Not ordered yet, but likely to do so shortly, and I too want a smaller plate plinth after reading the Guilia thread. I plan to buy a short number eg X 1 XXX so it follows spacing legality. I may make a purpose made plinth to replace the standard one, with rear profile to match bodywork sculpturing. But that may have to be part 2 of the plan...just need to avoid unfortunately placed holes in bodywork from part 1.
Please keep us posted!
I asked my dealer about getting the Italian plinth and he came back with two part numbers, 50535783 and 50541383 I'm not sure if these are the long and the short or two different short versions. I contacted AR customer services for more info and they sent back the following dimensions
Part Number - 50535783
Length: 38cm Width: 14cm Height: 3cm
Part Number – 50541383
Length: 25cm Width: 7cm Height: 76cm
These don't seem to make sense. 50535783 is about the right width at 38cm but very thick at 7cm and a bit too tall at 14cm. 50541383 is 3/4 of metre high...not sure what this is.
I've queried this with both AR and the dealer. Waiting for further info
Did you get any further info from Alfa on this? I'm trying to order one for my car.
Edit: MacGeek has kindly confirmed that 50535783 is the correct part number for the Italian market front plinth. For future reference he has also advised that the part number for the smaller Italian plinth for the upcoming Stelvio Quadrifoglio is 50552824 in case any potential buyers of that version also want to fit a smaller front plate.
I have got further with this. My dealer got hold of the Italian plinth and will fit it on my car when it is delivered. The plinth has a 5mm curved edge all the way round, so here are two sets of measurements - the overall and the flat 'internal' area.
375mm x 130mm
365mm x 120mm
Thanks. I've given up on my dealer sorting it out and have ordered one via EB Spares so should hopefully have it at some point next week.
Can't you just attach the numberplate to the big,
****_off chrome bull-bars you're all going to fit
on your SUVs? :confused:
My dealer called me unexpectedly yesterday to say they had finally received the Italian mounting plinth so I dropped round and had them fit it. If any other owner needs the short mounting plinth contact EB Spares as they have one in stock and are extremely helpful.
They are a pain in the arse, tin plates.
I had it happen all the time here in "06" land
before we went to non-departmental numbers.
And they get bent and ripped off by scooterists.
What made you choose them?
Discussion Starter #16
Purely aesthetics and an interesting material difference to the ubiquity of acrylic. In researching them I was aware of the potential drop out problem, so I did ensure the adhesive strips bridge those areas. Lets see if it becomes a problem...they were only £20, so not a huge loss if they do.
I have ordered a Milano from Glyn Hopkin in St Albans and when I signed on the dotted line I mentioned not drilling the bumper for the number plate plinth and said I would supply an Italian sized plinth and velcro. He said don't bother, have a look at Static Plates. I will be going down that route after having a look. He will fit whatever I want.:happy:
The front bumper does not require drilling. There are already little square holes in the flat black plastic section at the the top of the left hand side grille. The fixing screws for the plinth come with corresponding square fittings that simply press into these holes. Here is my Italian market short front plinth.
Discussion Starter #19
I got mine from St Albans. They got hold of and fitted the Italian plinth for me. Reading your post I looked at Static Plates, but it does say they aren't legal and just for show. I ended up getting 360mm wide pressed metal plates but I was talking to a company called 4Dot in Borehamwood that do short acrylic plates. Their website has good size chart that shows you the legal sizes you can get with different letter/number combinations. To get mine down to 360mm I got a 6 digit Irish plate with two 1s in the number. If you want to spend more on 5 digits or less then you'll be fine.
I already have a 6 digit registration to transfer onto the car.
I have had a 3/4 size plate on one of my other cars for 14 years with no problems so will probably take a gamble on the Static plate.
1 - 20 of 46 Posts
