You need to locate the 2 hotels behind the tight and left steering wheel spokes, insert a flat blade screwdriver down them, ideally of a similar diameter as the holes, give it a quarter turn and they should pop loose.
It's not easy the first time.
My mistake! I've definitely had mine off, but can't remember if there was 3 screws behind the spokes or that was the 147... Sorry!
It should be 3 screws, they are located close the the end of each arm, turn the steering wheel, and you should see 3 wholes within the leather part of the steering wheel. not sure if they are philips or torx type.
Discussion Starter · #7 ·
In all the steering wheels I've removed , I've never noticed those 3 screws .
Thank you for that.
