Welcome to one of the easiest, or one of the hardest jobs on a 105. The retaining nut seems to be in shadow on your photo, but if you can see the hole down which the yellow wire disappears, there should be a locking washer and a large hex nut around there.
You'll need a big socket with an extension bar to undo it. If there's no nut, count your blessings!
The nut should come off relatively easily. The steering wheel may be another matter. Sometimes they are dead easy. Others will be a real pig and you will need to get a puller on (be careful not to damage things).
