· Registered
As noted by some other posters I have the warning "Vehicle Protection System Unavailable" about 5 seconds after removing the key.
It's the Steering Lock not engaging. Does anybody know what the fix is? Is it a new steering lock or an electronic failure?
· Registered
Mine did not work for about 4 weeks so I threatened a trip to the dealer. On the morning of the dealer investigation it started to work again and has worked ever since (more than one year). Not much help I know but I'm thinking that the mechanism must stick somehow and once freed it seems to work OK so more of a mechanical problem.
· Registered
It sounds like the Dealer is ordering the Solenoid.
I have tried moving the steering wheel, a different key and heavy banging of the casing. It doesn't show up on the examiner but I did wonder if a battery disconnect was needed to unscramble the brain. I can't work out how it knows the steering lock is not firing and needs to put up the message. If it is purely mechanical you would think the system would fire the solenoid and not know that the plunger is not in the groove. But an electronic failure could be programmed to put up the message.
Thoughts?
· Registered
Steering Wheel lock
This happened to my 159 a year or so ago and I managed to get the lock mechanism off and took it apart, put it back together and it worked. This is not a job for the faint hearted, removing shear bolts is not easy, or the one way screws on the lock. It just happened again so this time after removing the key, I tapped the lock with a rubber hammer for several seconds, and after the second time the mechanism began working again. A much simpler fix .... if it works. :cool:
