Steering Alignment
929 5
I have just had my 1.9 JTDM Lusso (2009) in for steering alignment. Whilst the car feels better, the steering wheel is no longer in the straight ahead position and is off set slightly to the right.
I am concerned by this as surely this cannot be correct, and although I could have the wheel moved, I am concerned by the potential tyre wear.
Any advice would be greatly appreciated.
· Registered
--- Insist that they do it again properly.
· Registered
I assume this is not correct and moving the steering wheel is not the answer.
I will take it back. Is it just me or are 159's a real pain to set up in the steering department.
I had real high speed vibration issues previously. It is all becoming far too time consuming.:confused:
· Registered
It should be easy enough for them to fix, assuming the car isn't actually crabbing because the rear alignment is off.
If the steering wheel is to the right, the DS side needs shortened and the PS side needs lengthened by equal amounts (and the alignment rechecked). The other way round then if the steering is to the left.
