Hi guys, I am busy with fitting in a security key system to start the engine, same like you see in this movie.
My question is, the first part, the black and blue wire this guy is talking of...I should cut the wire that goes to the starter.
My first tought is that this is the (blackwhite) crank wire coming from the key, but a little bit further he talks about the orange wire that must be connected to the 12v crank wire.
Im a bit confused now. does he mean another wire then the black white crank wire?
The black and blue wire should be connected to the wire (to be cut) from the ignition switch to the starter
In the workshop manual the color of this wire is stated to be red, red/black or red/blue depending on motor version and year. (Ignition switch pin 50).
The red wire should be connected to a constant 12V.
The black wires should be connected to Ground (Chassis)
The orange wire should be connected to a 12V that is present with the ignition on and when cranking the starter.
The orange/light-blue wire from the ignition switch (pin INT) has this function
Hello Henrik, well this helps a lot!!! Let's see if this is going to work tommorow, I let you know!! Thank you
Yep, it works like a charm now, thanks for the intervention Henrik!! First it did not work, somehow they had put in another code, I had to reset it with the mastercode and all worked fine!
