1 - 12 of 12 Posts
When I start my car up it makes a ugly noise once the motor is running (a bit like if you kept the key on the starter position). Lasts about a second...
Anyone know what it is and is it a problem?
Probably the starter sticking slightly. If you undo the starter motor and slide it back you should be able to wipe off the shaft and apply a smear of light oil, although i have not actually done this on a GTV so not sure how easy (or not) it is to access.
R
Mine makes a noise on startup but it's just the aux belt squealing a tad, it was changed along with the tensioner last year so I'm not worried.
Good luck sorting yours out
ta all.... I know a mechanic that I'll get to listen to it just to make sure it isn't anything terminal...
someone told me you need to get the engine out to get to the starter.. that isn't true is it ?!
1 - 12 of 12 Posts
