Hi All
Does anyone know if I can run an AMP/Sub combination with the standard Alfa Headunit.
The head unit is capable of BOSE MODE...
Car is a 2005 Facelift 156
any help appreciated - if not - afternarket headunit will have to be....
Hi All
It's always possible.... You can just get an amp with speaker level inputs.
As above; most entry level amp have high level/speaker level inputs.
Alternatively, tap into the speakerwires with an LOC (line output converter). Does the same thing, and drops the signal level from high/amplified to low/line-level; then RCA cables from the LOC to the RCA inputs on the amp.
Short answer is 'yes, easy to do'.
