The CF2 has a big silenced centre cat, the CF2 has two small metallic twin cats which don't do as much volume reduction, that is why there is a big difference in volume between an original CF2 model and a CF3 model with decat manifolds fitted. Is your centre section silenced or also straight-through? If its straight through, we could add a silencer there to take the edge off. That would basically take it to a similar spec to your old CF2.Yes, I will probably sell the wizard but only once I have a car that isn’t rattling my brains. I can’t believe two cars can sound so different (my last cf2 had a wizard but not catted manifolds and sounded completely different)
If you go the manifolds route then it will get noisier up front, i also get a vibration through my left foot too.
On the motorway at 70 it is fine but thats only a small part of my driving.
Anyway, still kicking myself I binned a perfectly good exhaust
Are you absolutely sure there are no blows anywhere? Have you visually checked that the centre cats haven't dropped their insides? What downpipes are you using and are they in a decent condition? There's really not much room on the centre section for a bigger silencer, in place of the centre cats was always a better location but its a hassle to fabricate there because of the lambda sensors and that Alfa also used the centre cats as the collector for the two secondaries.Hi Pud, mine has the extra silencer but it is still really very ‘boomy’. most of the unpleasant noise is inside but outside it is still a bit antisocial.
I wonder if it is possible to make a centre pipe with a bigger/more effective silencer as it appears to me that the unpleasant noise comes from the boot area?
Or perhaps a backbox with more sound deadening, a more expensive route but I could sell on the original to offset the cost.
Thoughts?
