So I had to replace the pads on my V6 GTV. I ordered some Delphi pads which I then fitted. On my second or third journey I noticed a nasty rubbing sound which was caused by the shim on one of the pads sliding forward and rubbing on the disc.
I contacted Autosessive who kindly send me replacement pads. These were slightly different in that the shim went around the two holes for the pins so could not slip forward. Problem solved - or so I thought.
Since fitting the replacement pads I have had horrible, loud squealing brakes - but only when applying the brakes at slow speed, most often when coming to a stop. I am fairly sure the squealing is coming from the front brakes as I can gently apply the hand brake when moving slowly without any squealing.
I always put a layer of copper grease on the back of the pads so when the squealing stated I carried out some investigations resulting in the purchase of Mintex Ceratec which supposed to be better than copper grease and is specifically designed for this purpose. However, I still have squealing brakes!
Any suggestions?
Chris
Any suggestions?
Chris
