1 - 2 of 2 Posts
Lads,
Have a really annoying squeaking issue with my clutch pedal in my 147. Can't seem to locate where its coming from.
Any ideas where to start on locating it? Sounds like a creaking floor board in a horror movie...
There's plenty of posts on here complete with pictures of the part in question.
The clutch master cylinder acts directly on the pedal, if you drop the fusebox cover under the steering wheel, you will see a rubber bush and pushrod at the far left at the top of the clutch pedal.
Numerous people have quietned theirs with the aid of spray grease on the push rod and under the little rubber boot.
I had this issue on mine, and it didn't help at all, I had to replace the master cylinder shortly afterwards which stopped the squeak, not sure whether lubricating this contributed to the failure of the master cylinder or not
1 - 2 of 2 Posts
