Having discovered my radiator had a hole in which I've not replaced as yet, I decided to see where the hole was. I filled up the coolant tank and started the engine and waited for it to get hot. I noticed after a while there was no heating in the car so I turned the engine off to check the coolant and heard this noise from one of the hoses....I managed to record it just before it suddenly went off!:confused:
YouTube
As you can see water seeped out of the bottom. I turned the engine back on again to see if I could pinpoint the noise, at about 1.39 the noise starts up again.
I am hoping that it's merely air pressure pushing coolant out at the weakest point and can be rectified with a new radiator, thermostat, bleeding and a hose check.
Can anyone confirm this for me please?
Thank you
