1 - 16 of 16 Posts
· Registered
Got the same on my 156 with the n/s wheel, but mainly on left turns. As your problem is with the o/s that would explain the difference from left to right perhaps. Does it go away when you lightly touch the brake pedal - mine does.
The dealer says it is the front pad touching the disc so it's OK then??
· Registered
It should be fine, as the pads wear more the distance between pad and disc may increase and the noise will go away :)
Other than that the caliper could be taken off and cleaned up greased to make sure it releases properly :eek:
Discussion Starter · #6 ·
that sounds like the same symptons hope it is that mot is due :(
· Registered
Stori said:
Well I would check the play in the front wheel bearings.......may be too much and need an adjustment........I had a similar problem with an Alfetta GTV :eek: ;) :D
I didnt know wheels bearings could be adjusted :eek: :confused:
Dont worry about it m8, does sound like any thing that will fail an MOT :)
· Registered
The bearings can wear and produce movement. Although no adjustment is possible, retorqueing the bearing nut can reduce the play.
It could be worn brake pads, or the pads could be tight in the caliper carrier. If so remove them and fill away the brake dust and corrosion to allow a sliding fit.
The other thing is static build up. Fitting shims were developed for applications which tend to produce brake noise. Also, copper grease on the rear of the pad should stop any humming or constant squeaking in this sort of situation.
Discussion Starter · #14 ·
I have just had new pads all round, the discs were fine. And the calipers checked BUT i've got the same Bloody squeal at times quite loud.....
its going back in to be "looked at" must be new pad related... :eek:
· Registered
It can come from some brands of pads more than others. Also, driving technique can affect the brake noise. Ford circulated a technical bulletin a while ago to say that very light prolonged check braking can produce a glazed pad and hence noise just the same way that an overheated lining can! Moderate braking is the order of the day. :lol:
Discussion Starter · #16 ·
I've just changed the discs and pads on my V6... had excatly the same fault. On mine it was just the backing plate touching the disc.. took 2 mins to fix, just bent them out a little with a screwdriver
1 - 16 of 16 Posts
