Like most 155 owners I have noticed both of the front doors seek alot. What I have found out is that if you pull on the handle then the sqeek stops.
So what do this mean,
1, I need to replace the rubber door seals,
2, Or adjust the catch plate to ensure the door
is closed tighter.
Marcus
Discussion Starter #2
Depends where the squeeking is coming from. It may be that the door has dropped slightly on the pins and your catch is fouling, grease it up and its fine. If the door is squeeking through movement then yes, adjust the catch inwards a little but be careful. Too much and you will sprain the top frame.
wrinx
