Power flex bushes are a doddle to fit. Lots of coppaslip, put the inner sleeve in after you have put the plastic bushes into the pans. Can be done by hand with the inner sleeves requiring a tap with a rubber mallet. Just done mine.
Pressing the old bushes out can be tricky, without a proper press. I welded up a framework so I could use a 20t bottle jack as a press. A little application of heat around the bushes worked wonders.
