Hello all.
Does anyone know if the sideskirts off of a 2.5 v6 are the same as those on the standard 2.0TS Sportpack cars?
Also, are they hard to fit in a DIY manner? I can't imagine so but just figured I'd check.
Cheers!
Yes TS / V6 skirts are the same.
There were early & late versions though.
The late ones had an extra screw fixing at the top at the rear with a cover over it.
Probably the best way to DIY fit would be to use the stuff that bodyshops use to stick kits on.
Sikaflex, not sure which one though.
There are also the small plastic clips that Alfa use that, of course, break if you ever try to remove the skirts. Or in my case, will snap when a spanner jockey uses a 4 poster lift without raising the ends so that the arm crunches into my skirts and attempts to remove them as the car is raised . . . GRRRRR!!!
Not sure how the clips fix on but you can get them for not a lot from Alfa. Pins on the skirts fix into the clips ont he car.
