love them or hate them i have bought myself a zender boot spoiler
few questions on fitting...
wiring the brake light, do you use the wire running to the existing window brake?
is there a way of blanking the existing window brake?
just bolt it on or use some kind of adhesive? or both?
does it mount straight to the boot lid, or should i use some kind of rubber gasket?
finally, will it foul the electric aerial?
thanks
Usually there is a cover that goes over the space left behind by the high level brake light.
Yes you can attach the wiring to the existing multi plug but you should notice that there is a rubber covered loom running along the boot hinge for the remote boot release that you can run the wires for the spoiler brake light through.
It's drilled holes into the boot lid and bolts. Sticking it down won't suffice, a sender spoiler can produce 200+kg of down force at 80+mph and the last thing you need is that to come off and going through a car that following windshield at that speed.
Aero pack can increase the top speed by 5mph+ coincidentally!
No. If positioned correctly it will not affect or foul the standard electrical powered aerial.
