got home tonite and the 147 was making this chaffing metel on metel noise traced it to a plate on the alternator is it ment to spin or be still mine is loose,only had car 4 days and seem to find something wrong every day,still a fan i must be mad!
Discussion Starter #2
sorry my mistake its not the alternator i think its the air con pump the one at the bottom front?
You are right - it is the zircon compressor unit. It has an internal clutch, so if the zircon is turned off, that plate remains still. Turn the zircon on and the clutch engages and it will spin. If it doesn't do this it's broken, and with a little hunting you can find a good second hand one - about £80, plus £200 to fit at an independent garage ( make SURE you find one that knows Alfas ). I can recommend Alfa Workshop.
thanks for that i think the air con has packed up now only picked car up saturday and the list of things to do is getting bigger and bigger.
Air con won't work if temp is below 3C ... which it probably is!
