Hi, was wondering if anyone knew of the top of their heads what size the screws are that are used to attach Rear Screen Section to hood frame, I had the usual seized and sheared nut which i then drilled out. I now need to replace and the two screws that i need to renew are the two larger ones that are the last screws on each side.
Regards,:)
Somewhere on this forum I did a write up of replacing rear screen. I had same problem and local motor spares shop advised B&Q. They had some screws that are exactly right which I used. http://www.alfaowner.com/Forum/alfa-gtv-and-916-spider/356778-hints-and-tips-for-fitting-rear-roof-panel.html. The heads stand a bit proud but as you wrap the hood around the fixing bar that is no problem. Has worked fine on mine and I've had them in for a few months and used hood several times.
