1 - 9 of 9 Posts
I have a noise which has always been present but isn't causing any issues…I am just curious to what it is.
When I turn off the ignition or when the key is at MAR and is switched off, there is a sound that can only be described as Pac Man munching something three times… like munch munch munch.
…Any ideas (and I am not going mad)
:confused:
If the noise is at the front and the car Phase 2 or 3, turn the heater to speed 0 and switch the a/c off and see if the noise goes away.
If the noise is from the back, possibly fuel pump.
pkr....I will try that tonight...it is coming from the front of the car around where the throttle body is
Dont know about ph2/3 but on ph1s when the ignition is turned off the air recirculation flap closes, makes a faint whirring noise on mine.
Like I say, its not causing any issues (touch wood) but was just curious....do they all make that noise?
Still makes the noise with the fan set to zero.....will try and record it...just trying to see if it is a problem or if anyone else has the same noise...
Mine a 1999 model makes a similar type noise, we have nicknamed it the duck, as it like a funny quacking sound?
Think it from somewhere near the idle control thingy
cheers
Joe
1 - 9 of 9 Posts
