Hi All can anyone tell me where to find the fuse box that has the fuse for the airbag also does this fuse operate the internal and boot light
You are mistakenThe first year of production was 2005 and minor changes 2007 unless I am mistaken.
Thanks PKR just found the one's you are on about unfortunately they are all good, do you know if the LED's can blow on the dash as ive got no oil light and the NS door a jar is only half lit ive checked the oil switch with a new one and still no go,You are mistaken
The Spider you are referring to is the Nuovo Spider (946) that was produced from 2006
The one under discussion is the 916 model that was produced from 1995 - 2005
They're unlikely to blow - they generally have a life of many 10s of thousands of hours.Thanks PKR just found the one's you are on about unfortunately they are all good, do you know if the LED's can blow on the dash as ive got no oil light and the NS door a jar is only half lit ive checked the oil switch with a new one and still no go,
Thanks PKR, I will have a look and see if this is the case, cannot believe some one would actually cut lamps out of circuit to try and defeat a fault, hopefully this is not the case,They're unlikely to blow - they generally have a life of many 10s of thousands of hours.
Not unknown for previous owners or dodgy garages to cut the LED out of the instrument pack rather than fix the actual problem ...
The oil w/l is on a different connector at the instrument pack to the airbag & door warning light so no commonality there ( loose connector? ).
For the door w/l, it could be an early indicator that the switch in the door lock is failing. Maybe.
I'd open up the instrument pack to have a look. Maybe some idiot snipped the oil LED thinking it was the airbag LED and then snipped the airbag LED as well!
Easy to do. Unscrew the two allen bolts holding the instument pack ( you can see them at the top of the pack ). Fully lower and fully pull the steering wheel towards the seats on its adjuster. Ease the instrument pack out and undo the two connectors at the bottom ( one white, one green ). The cables may be hooked to plastic clips on the rear so slide them out and the pack will then come free.
Undo two screws in the plastic cover at the back and remove the cover by easing off the plastic clips.
Undo the five screws holding in the PCB. Ease the PCB out gently - the speedo and rev counter connect to the PCB by pins passing through the board. They'll come free with gentle easing.
You'ld be surprised at what people do in cars. I've had my Spider for over two years now and I think I've just about sorted out where all odd screws and fastenings I found in it actually fit.Thanks PKR, I will have a look and see if this is the case, cannot believe some one would actually cut lamps out of circuit to try and defeat a fault, hopefully this is not the case,
Thanks for all your info been having a look at the instrument panel, took it all apart I mean everything and removed the centre legend and found some one had put black tape over the airbag led holeYou'ld be surprised at what people do in cars. I've had my Spider for over two years now and I think I've just about sorted out where all odd screws and fastenings I found in it actually fit.
Thanks PKR Will check out this weekend and updateOK, good result so far.
To test your oil light :
The green connector on the instrument pack is an 18 pin connector.
You want pin 10. Looking at the wire side of the connector and the locking clip upwards you have pins 1 through 8 on the top row going RIGHT to LEFT(!) and 9 to 18 on the bottom row also going right to left.
So, first double check -
pin 1 ( top right ) should have a wire coloured black
pin 8 ( top left ) = white
pin 9 ( bottom right ) should have no wire
pin 18 ( bottom left ) should have no wire
pin 10 bottom row, second from right should have a Grey/Black wire. And as a further precaution, pin 11 is Grey/Yellow!
Now, get a piece of wire and strip a bit of insulator off each end. Twist the ends to prevent loose strands.
Hold one end to a earth e.g. cigarette lighter body or any bit of unpainted metal on the car body, turn on the ignition and push the other end of your wire carefully into pin 10 of the connector ( obviously still plugged into the instrument pack! ). Ensure no stray strands touch adjacent pins!
If the oil light LED is good, and everything else about the instrument pack is also good, the oil w/l will now light up.
If that checks out, the wiring up to the pressure switch can be checked next.
yes have one of thoseDo you have or access to a multimeter?
OK, I can come up with some further tests for you to establish what's wrong.yes have one of those
