1 - 2 of 2 Posts
Hi all, hoping someone can help me roof closing issue have checked ecu with multiscan via 3 pin dlc
can anyone give any information on dtcs the roof works ok except when the fabric/screen section is lowered it stops followed by ref light flashing initial scan revealed codes 11,15,64 cleared codes and now I’m getting a code 13 interference detected faulty signal
Kind regards John
Hi, sounds like the ecu is confused over the position of the roof.
I suggest the following as may help.
First disconnect the battery and leave the car alone for few hours, ideally overnight. This will clear the logic and reset the ecu.
Get some electrical switch contact cleaner, and with the cowling up spray over the four microswitches. There are two each side where the cowling locks down.
Hopefully you will then be in luck 👍🏻
1 - 2 of 2 Posts
