Hi folks,
Been on and off this forum lots over the past 5 years and it has often saved my sanity when 'her' Spider decides to come over all Italian! Seen lots of comments about flat spots etc, often down to MAF issues. Her car has been modified at some point in the past, the air cleaner system has been replaced with a short pipe from the throttle body to the MAF, then a cone filter. Overall inlet tract length is therefore much shorter than OE. The car has always had a bit of a flat spot, but has generally been fine to drive, but recently it failed MOT due to high O2 readings (Lambda). I replaced the Lambda probe and MAF sensor (both OE Bosch items) and the car passed MOT - just. Looking at the emission test results, the car is still running lean, and the flat spot is, if anything, worse with the new sensors. I can't imagine the intake mods will have affected the mixture, (it should be a closed loop control system), so wondered if any else had suffered similar issues with lean running??
I am trying to collect all the various bits needed to reinstate the OE intake system to hopefully rule that out as a cause.
Any suggestions welcome!!:thinking::thinking::thinking:
