1 - 19 of 19 Posts
Any tips/advice for removing the speedo sender unit from the diff on a V6 ????
I can see it...just...and can touch it...just....but can I get a hand in with a spanner ????....No Way !!!!
Not much room at all in there so any pearls of wisdom to help me remove it would be very gratefully received.
Is that you offering yer services ???
Thanks, I accept...and your not allowed to use the welder !!!!!
PS I have a nice exhaust that you CAN use the welder on before I put it on the Silverstone
To complete any job.. it is imperitive that you weld SOMETHING!
will have a look tonight.
j
Sure Speedy will come along and say its dead easy to get to and I've not looked so this is only a suggestion but how about a "crows foot" spanner. Little things like the end of a spanner that attaches to a socket so you could put the extension on it ;) Halfrauds stcok them.
wrinx
Discussion Starter · #6 ·
gonna attack it from underneath again tommorrow. I've discovered it's a 22mm spanner, hopefully I can get it...or it's off to the garage. Gonna get the belt done anyway, should be cheap enough for that.....I hope.....
Trying to remember ...............but i think it`s easier to undo from the top :confused:
Get yer hand down under the air flow meter and put the spanner on at an angle .............it should`nt be that tight and there`s more room in there than you think ;)
Btw the cambelt is cheap enough about £25 for an original Alfa one ..................it`s the tensioner thats expensive about £60 i think
Make sure you get the tensioner changed as well ;) ;)
There pretty easy to change yerself just a bit tight for space ..........think i did mine in about an hour or so :D :D
Discussion Starter · #8 ·
:cheese: ...sorry Marl...as u know...any advice from me
would prove useless to the point of needing Mental Surgery :eek:
...I love this stuff though :p :lol:
...DAD...let me stay another few minutes :eek:
Discussion Starter · #9 ·
Speedy's about right with the prices...might be an idea to do the water pump while you're in their....just an idea tho ;) You'll need to check the other belts as they need to come of anyway (from memory...or am I thinking of the twinny!?!?!).
wrinx
wrinx
As far as I can remember from my Alfa 75 days the belt has to come off to do the Water Pump. :rolleyes:
You just need to take the auxillary belts off to do the cambelt :rolleyes: and the plastic covers ;)
No need to remove the water pump :confused:
Ah i see what yer mean now :rolleyes: Sorry about that must be the smell of leather affecting me :p :p :cheese: :cheese:
But you did say that " pretty sure it all had to be removed to do the belts" :confused: :confused:
Discussion Starter · #15 ·
wrinx said:
Correct, pretty sure the lot has to come off to change the cambelt ;)
wrinx
*pedantic mode on*...by "the lot" I meant belts ;) Perhaps I wasn't clear enough for one so obsessed with leather and its evils at the moment :rolleyes:
wrinx
wrinx
:D :D :D Everybody needs an Obsession.........................just mine usually involves Whips etc etc :D :D :D
Discussion Starter · #17 ·
Speed, I believe that Wrinxy has switched his "envy mode" on but has forgotten to switch it off. :tut: :tut:
I think this may be "on" for some time...... ;)
Discussion Starter · #18 ·
Envy...me :eek: I have no idea what you mean...why on earth would I want to fill my car with bits of dead cow :rolleyes: ...how ridiculous :lol:
wrinx
Look`s like yer hit the nail on the head Barry :D
Btw think i should ring him up to Gloat AGAIN :p :p :cheese: :cheese:
1 - 19 of 19 Posts
