I had a blown bulb on the speedo (156 1999) that was annoying me. Decided it's an easy fix. :rolleyes: Removed the Speedo without any problem, took the back off, replaced the bulb, put it all back together .... Result - No bulbs are working..... so I replaced both bulbs again .... nothing! The speedo still works and the LCD mileometer is working.
Any idea what I've done wrong? Connector blocks are in firmly. Is there a fuse for those lights?
what do you mean tool the back off. the bulbs can be accessed via the bulb holders from the rear of the clock
I had to take the black outer casing off 'cos of my fat fingers. Would that have caused a problem?
All other lights work, except the boot lamp. Only other electrical issue is the normal erratic aircon/blower which has been with this car from new (have to reset it regularly - Full heat, #4 & demist)
Long nose plyers are easier ;)
