HI,
I just brought a 155 v6 /93 2 days ago.
The problem is that the speedmeter is not working,
and the wipers only working on high speed.
Does somebody know what the problems can be?(bad contact or so in the pcb/sensor).
The problem with the wiper is also that they took out a relay (A727 509) and i dont know where to put it back in the fuse compartment.
Because i dont have a manual.
Can somebody send me a schematic diagram of the speedmeter and the wiper circuit.
Thanks from a cold holland.
Piet.
was it the intermittant relay they took out if so goes in top left of fuse box reference speedo has cable snapped
Speedo is electronic ,probably the sensor attached to the gear box needs replaced ,can`t tell you exactly where it is but mine had gone a while ago but simple to sort,try a s/h one.cheers pat
Piet have you tried the alfa romeo tuning club in Holland , i'm sure these guys can help you out...they're a bunch of 155 loons too .
