1 - 2 of 2 Posts
Hi guys thought I'd throw this little quandry out to the 916 hive mind.......
Ph1 Spider rear speaker not working
passenger door speaker not working
drivers speaker awesome
ariel occasionally not rising but radio still crystal clear
if I adjust the balance its reversed ie full right (driverside goes quiet) full left driver side loud and clear. wiring at the back looks like mamas best spaghetti.
Re the ariel does it only lift it needs it? or am I crediting it with too much intelligence?
All advice and suggestions greatfully recieved
VBM
I would try disconnecting the sub-woofer to see if the fronts work properly.
I understand it is a twin coil speaker and if there is a short it may give your symptoms.
Is your head unit OE or aftermarket?
What ever it may be better to remove head unit and tidy wiring up.
1 - 2 of 2 Posts
