:tut: hi everyone .I just bought my 147 1.6 ltrs.It was overfilled with oil(over an inch over the max mark on the dip stick) and I notised that there is a leak and it makes lots of blue smoke .what should I do.Do Ihave to go to a garage or wait untill the oil goes lower.The engine changed its noise sounds like a diesel abit.can anyone give us a clue
thanks for that advice I will drain some oil and see what happens.I was just wondering from where the exesive oil might leak,because I found som under the car lasst two nights
could be leaking from the sump plug or directly from the filter, if there is to much oil in the car it needs to try and escape from somewhere.
Spaz78: Did you test the oil level when the engine was hot or cold?
Diesel sound: only on starting from cold or all the time?
