does anyone have any experience of bosch sparkplugs in a t.v 16v 2.0 engine good or bad? Stefan
In a 16v TS, there is no reason to use anything other than the original spec Platinum NGK Plugs:
4x NGK BKR6EKPA
4x NGK PMR7A
They last 5-years/60000miles/100000km.
Exept cash David.My motor has managed 190.000 km and probably won´t need the ngk guarantied 100.000 km in Sweden the 8 plugs from NGK would put you down about 200 pounds.
They often sell for £50-£60 in the UK.
Buy from here and ship to Sweden.
Thanks for the answer David i´l check the web and order ngk´s from the U.K.You are living on the right side of the northsee if you´r going to by sparkplugs then:).
It would seam so!!
But saying that, main dealer prices for the same plugs are often considerably higher here too.
Check on eBay and also check with EB Spares because they are used to exporting parts.
