· Registered
Maybe just get a cheap 16" alloy?
My Sporto has 17" horseshoes, but my spare is a regular 166 16" wheel.
So long as it is a V6 wheel, it will clear the brakes. The diameter is of course maintained by taller profile on the smaller wheel. Fits is the wheel well, fairly well but does raise the boot floor a little.
· Registered
As above, a 16" alloy and normal tyre is a much better bet than a skinny spare.
Usually reasonably easy to find a single wheel if you are not too fussed what it looks like.
· Registered
5x108mm is the PCD you need.
Probably Jag "X Type", which share a lot with Ford Mondeo, which are also 5x108mm PCD.
Not sure on the centre-bore though.
