hallo hallo hallo
my cam variator is very diesely, engine done 37K so not too happy :( ...i have been quoted about £300 to have this done by an alfa specialist or if i have the belts and tensioners done at the same time its £500. is this a fair price? and does this need to be done by an alfa specialist as their rates are quite a bit higher than the garage i have always used in the past that does all cars (no speciality)
thanks in advance....see you at stanford hall
HI CRIPPY, I SUGGEST THAT FOR THE CAM VARIATOR, BELTS AND TENSIONERS ONLY A SPECIALIST PUT HANDS ON YOUR MOTOR.
IT IS A VERY SPECIFIC WORK IN THE 16 VALVS.
REGARDS
JORGE :p
This is a common enough job for an alfa specialist so call a few other garages and ask for a quote - they should be able to give you a quote on the phone.
