2017 Guila 2.0 Tbi Lusso spec, 1972 S2 Spider Junior, wife drives 939 Spider, + Abarth 595
The only problem with that is that with the uncomplicated nature of our cars, unless there is a steering lock involved, you dont need an ignition key to start the car. In fact, put a hidden switch in the ignition circuit and armed with a length of wire under the bonnet you can bypass that switch within seconds.I'm thinking about a hidden ignition master switch, as anything more may be too tempting for me to not use if I'm "only gone 5 minutes"...
That might be OK with a newer classic with fuel injection like yours Simon, but old cars on carbs, its no better than a 'secret' switch.A fob based insurance approved immobiliser is great.
Good points. For out and about then, it sounds like it needs to be something like a steering wheel lock, or immobilisation through removing something vital like the King lead?The only problem with that is that with the uncomplicated nature of our cars, unless there is a steering lock involved, you dont need an ignition key to start the car. In fact, put a hidden switch in the ignition circuit and armed with a length of wire under the bonnet you can bypass that switch within seconds.
What you can do is to isolate the main cable feeding the starter motor, even then though the car could be bump started, but there would be no indicators, lights etc working.
One of these will stop an opportunist, but not a pro, he'd have a spare key:Good points. For out and about then, it sounds like it needs to be something like a steering wheel lock, or immobilisation through removing something vital like the King lead?
That's actually what I meant when I said "ignition master switch" as I've put these in kit cars in the past and they effectively stopped battery the discharging itself over time. While they take some ingenuity to hide, I'll give one a go.One of these will stop an opportunist, but not a pro, he'd have a spare key:
http://www.amazon.co.uk/BATTERY-ISOLATOR-MASTER-SWITCH-UNIVERSAL/dp/B007CGPASW
That's what I fitted - apart from the security aspect - it is easily bypassed by someone who knows their stuff - its great for preventing battery drain and also safety when your working on the carOne of these will stop an opportunist, but not a pro, he'd have a spare key:
BATTERY ISOLATOR MASTER SWITCH - 2 KEYS - UNIVERSAL: Amazon.co.uk: Car & Motorbike
Fixed that for you.A fob based insurance approved immobiliser is as massive pain in the *rse when you just need to move the car .
