These are quote and costs for Q2 and cambelt work at the closest garages to me in Hexham. Hope it helps someone:
McLennans Edinburgh :
Timing belt, main tensioner, water pump =£559
q2, gbox oil and new bearings =£575
Lyles Newc: 0191 273 0700
Timing belt, main tensioner, water pump =£710
q2, gbox oil and new bearings =£wont do it
other work =£62 = vat p hour
service without plugs =£210
AlfaTeck: 0191 2529347
Timing belt, main tensioner, water pump =£619 +vat
service without plugs =£180 + vat
other work =£50
Benfield: 0191 211 2200 - Kevin
service without plugs 36k =£379
other work =£90 plus vat.
Timing belt, main tensioner, water pump =£740
Alexanders:01642 679782 - martin
Timing belt, main tensioner, water pump =£612
q2, gbox oil and new bearings =£ may do it - needs to be discussed
service without plugs =£149
other work =£80 + vat
R & P Woods: Newcastle 0191 281 0748
Timing belt, main tensioner, water pump =£lab only = 331
q2, gbox oil and new bearings =£may do it - needs to be discussed
other work =£48
county motors: carlisle: 01228 553027
Timing belt, main tensioner, water pump =£846 inc vat
q2, gbox oil and new bearings 6 hrs =£450 excl
service without plugs =£220
other work =£40
Try All things Alfa in Thornaby, they seem pretty good. Also a bloke on here has had his done at FAST in Stockton on Tees.
im from carlisle, and got my q2 done and brakes from mclellans garage, they were spot on!
Reekie,
Those prices from Benfield are your normal punter prices, if you tell them you are from this forum you get a substantial discount.............and Steve and Mark the Alfa technicians at Benfield are second to none...........still may be slighly higher priced than others but then you get that main dealer/Alfa back up should any problems arise!
J.
Phew, just makes me realise just how much money I save doing all the regular stuff myself... Gunna tell the missus now and make her see that what I spend on Alfie is "justified":lol:
