Solved-p2563 in 2.0 jtdm
9.7K views 7 replies 2 participants last post by  M0ises
#1 ·
Hi, this afternoon i finished my task of changing the oil seal. After some movement appeared the message "check engine".
With my obd appeared p2563 P2563-Turbocharger boost control position sensor circuit range/performance.
any idea?
I´m terrified...
#6 ·
Indeed, nice to have shared for when others encounter the same.
Would be interested as well to share how you went on with the initial repair, replacing the pump seal.
Easy job, or lots of hassle?
here you have some instructions ;)
#5 ·
Today I will post some pictures about changing the seal in the original thread.
Really this pipe doesn't has any relationship with the oil seal replacement at all. I took off the pipe to screw a bolt in the EGR cooler because I saw an small leakeage and I forgot to plug It again.
In my opinion to change the oil seal is only for people who have skills with tools. First time took me too many time, now I'm sure I could do it in a day because I know the tricks that I will explain in the original thread.
I don't know in the Opel Insignia but in Alfa you don't have to dissamble the drive shaft at all.
