Are there any canbus issues when using a solar charger via the *** lighter?
Certainly the case in my GT, and I assume the 147s are the same.. Aux power is switched when the ignition is in the MAR position.. Otherwise nada...most lighter sockets are connected to an ignition switched +12 though, so doubt that would work if you want to use it to maintain charge .....
