From under the bonnet near the steering fluid reservoir. But looked tonight and no leaks.
Noticed a bit of oil behind head in dip in intake.
Then found most of the cam cover screws are loose!! Must have worked loose since gasket change but I know they were properly tightened.
Another new gasket or just clean up and replace? It was new when I did the head gasket.
Clean and retighten should be okay. Don't over tight en.
Didn't last time .. which is possibly why I'm in this pickle!
Anyone know the torque rates off their head? I can look them up later ... don't worry.
Think the rocker cover is only 10nm.
Fairly that you could use a sealant. But I don't like using that stuff just in case It goes down the oil wells.
I used a bit where it said in elearn around the front corners near the cam gears, but I think it is just because it is loose. It was fine for a few weeks so it's slowly been loosening up.
I'll tighten it back up and see what happens. Will take a day or two to burn off the residue I expect.
Thanks for the settings scottyf .. I probably just "nipped" them up before.
Worse thing you can do is over tighten. It then flattens the gasket and it no longer creates a seal.
Thought I'd check the manual ... Not that I didn't trust the advise.
Elearn ... Not quoted
156 DTE ... Not quoted
147 DTE ... .8 - 1.0 DaNm or 8-10Nm
Autobook ... Not quoted
Didn't google it ....
