So after a failed seatbelt was repaired (I know bit scary) I got my car back, drove home and noticed one of the parking sensors has moved back in its housing approx 2-3 cm. I think the dealer has cleaned my car a bit too enthusiastically and pushed it inwards! It still works as I checked. I wanted to ask:
1. How easy is it to re-position the sensor (push it back forward?) I have looked under the car and there is no obvious access point. I could take it back to the dealer however I think they might charge? Not sure but I assume they will try and pin it on me and claim its my fault.
2. I noticed with the sensor in its current position back there is now a small hole in the housing which has been exposed. Could this be a problem with water ingress? Bit worried as I don't want the whole thing to short out should some water go in there, however I assume everything is very weather tight round there given the amount of spray in bad weather etc. Any thoughts?
I am quite a non technical person so I am a bit anxious about poking around, but as my garage is quite a way away I am not really keen to go back unless I really should. Any thoughts on what to do?
