Hi. I have a 96 145 C-Leaf that needs a new Slave cylinder. Id like to do this work myself but have so far been unable to locate anything in the way of a repair manual for a 145. Any ideas would be much appreciated.
Slave cylinder is an easy job. You might want to take the battery out and battery tray to ease your access, after that it's just a case of taking the old one off, replacing it and then bleeding the cylinder.
Manual...ebay :D
wrinx
as the guys have said, easy job, about a 1.5 spanner in haynes speak, all you'll need are 10 and 13mm sockets and a 9mm(I think) spanner, maybe circlip pliers depending on the type of cylinder fitted, have a good look before attempting to order though, there are 3 different types!
I've been buying stuff from AlfaShop recently, very good, very fast delivery and recently I've found cheaper than shop4parts ;)
do you need a step by step how to?
